Data Reviewer batch in ArcGIS Pro doesn't honor Changed Features Only option
816
06-08-2021 05:51 AM
LisaBrimhall1
I am using a data reviewer batch file in ArcGIS Pro and have selected the 'Changed Features Only' option. Unfortunately, it doesn't seem to be working. I ran a batch job on a brand new version with no edits and then again on the Default version (the parent) and in both cases errors were found. We are using traditional versioning and the checks are only running on one feature class (no secondary data resources). My understanding is if the feature wasn't edited (ie different from the parent) it shouldn't be checked, so no errors should be returned. This is how it works in ArcMap, I ran the same scenario and no errors were returned. Is there a trick to getting Changed Features Only to work?
Thanks, Lisa
KumarGaurav_Esri
Hi Lisa,
Thanks for letting us know about this issue. After reproducing locally, I have logged an internal bug to resolve this issue. I'll keep you posted with the updates.
Kumar Gaurav
LisaBrimhall1
Great, thank you!
