I am in search for a list of the REVIEWERCODES that are assigned to the checks results inside the REVTABLEMAIN. This is a numeric code that is assigned via the REVIEWSTATUS (The error description) values.
Hello @DesireeWeitzmann
Is it this one you are looking for: https://pro.arcgis.com/en/pro-app/latest/help/data/validating-data/results-and-life-cycle-phases.htm ?
Paulina
Hi @Paulakark ,
No. Those are the codes for the LIFECYCLESTATUS, LIFECYCLEPHASE and VERIFICATIONSTATUS fields in the REVTABLEMAIN table. I am looking for the codes for the REVIEWERCODE field. I can not seem to find any documentation on this.
The values used in the REVIEWERCODE field is not currently documented. Could you provide some background/examples of how you are using them in your workflow?
Thanks in advance for the feedback!
Hello @JayCary ,
We use the REVIEWERCODE to help make a unique identifier in our correction process. Unfortunately we do not have enough Data Reviewer licenses for each editor (we have may editing groups). Right now , we use Data Reviewer to discover the defects via checks and then export the REVTABLEMAIN out to a database that all editors have access to. We use that to track and report on defect status.
We have checks written that do not have any results yet. So I am unable to tell what the REVIEWECODE would be to ensure that in the future the defect would be assigned a unique id.
