ArcGIS Data Reviewer Ideas
Other Boards in This Place
Latest Activity (18 Idea Submissions)
Sort/Filter :
Closed
In ArcMap, I used to be able to group records in the reviewer table based on multiple fields - https://desktop.arcgis...
AllisonWeide
by AllisonWeide Occasional Contributor
in ArcGIS Data Reviewer Ideas Last Updated 03-03-2025
0 3
In Product Plan
Hello, I’m using Data Reviewer, and I was wondering if there is a way to leave comments or notes linked to the errors...
AaronCrisanto
by AaronCrisanto Emerging Contributor
in ArcGIS Data Reviewer Ideas Last Updated 10-23-2024
0 4
Under Consideration
Add the ability to sort and filter fields in the ArcGIS Data Reviewer, Error Inspector Table in ArcGIS Pro. This func...
BethanyHodge
by BethanyHodge Occasional Contributor
in ArcGIS Data Reviewer Ideas Last Updated 08-02-2024
1 2
Already Offered
I would like to create a check that would take a point feature and check its attributes to nearby line features.  Exa...
TelecomMaps
by TelecomMaps Emerging Contributor
in ArcGIS Data Reviewer Ideas Last Updated 06-06-2024
0 3
Implemented
The ArcGIS Pro Browse Features tool does not select the feature it zooms like it did in ArcMap.  Currently, the Brows...
LPowers
by LPowers Occasional Contributor
in ArcGIS Data Reviewer Ideas Last Updated 11-08-2024
3 3
Implemented
The ArcGIS Pro Browse Features tool does not zoom to the feature's envelope extent like it did in ArcMap.  Currently,...
LPowers
1 3
Closed
ArcGIS 3.0.1: Having an option to enable\add the “reviewer results” for a particular geodatabase by right clicking, I...
JamalNUMAN
by JamalNUMAN Legendary Contributor
in ArcGIS Data Reviewer Ideas Last Updated 05-30-2024
1 1
Implemented
It would be nice to have a converter to translate .rbj file (Data Reviewer Batch Job) in ArcMap into "Attribute Rules...
PascalVezina
by PascalVezina Frequent Contributor
in ArcGIS Data Reviewer Ideas Last Updated 06-24-2022
1 2
Closed
In ArcMap we can build regular expression checks on editable fields, and in Pro we cannot, we need the ability to cre...
TedCronin
by TedCronin MVP Alum MVP Alum
in ArcGIS Data Reviewer Ideas Last Updated 02-22-2023
0 3
Needs Clarification
Hello,In ArcGIS Desktop, Data Reviewer supports the ability to edit records in a session. This isn't currently availa...
LisaBrimhall1
by LisaBrimhall1 Occasional Contributor
in ArcGIS Data Reviewer Ideas Last Updated 09-01-2022
7 5
7
Under Consideration
Hello,In ArcGIS Desktop, Data Reviewer supports custom (user-defined) fields. This isn't currently available in Pro. ...
LisaBrimhall1
in ArcGIS Data Reviewer Ideas Last Updated 08-08-2024
7 6
7
6
This idea has been relocated to the ArcGIS Pro Ideas Exchange.
SSWoodward
by SSWoodward Esri Contributor Esri Contributor
in ArcGIS Data Reviewer Ideas Last Updated 06-24-2021
0 0
Closed
I have seen questions on GeoNet about this, but not on the idea board. Is there a plan to allow for the creation or u...
Brian_McLeer
by Brian_McLeer Frequent Contributor
in ArcGIS Data Reviewer Ideas Last Updated 07-01-2021
1 3
Implemented
When doing spatial selections, you traditionally have options like Intersect, Contains, Boundary touches, and many, m...
MartinHvidberg
by MartinHvidberg Regular Contributor
in ArcGIS Data Reviewer Ideas Last Updated 11-11-2021
4 2
Implemented
With Esri support we verified that there is no way how to check following checks when need to compare feature class a...
JanBorovanský
by JanBorovanský Esri Contributor Esri Contributor
0 2
115 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
