ArcGIS Data Reviewer Blog
91
33.4K
40
Under Consideration | The ArcGIS Pro Browse Features tool does not select the feature it zooms like it did in ArcMap. Currently, the Brows... by LPowers New Contributor III 3 1 | 3 | 1 | |
Under Consideration | The ArcGIS Pro Browse Features tool does not zoom to the feature's envelope extent like it did in ArcMap. Currently,... by LPowers New Contributor III 1 1 | 1 | 1 | |
Open | ArcGIS 3.0.1: Having an option to enable\add the “reviewer results” for a particular geodatabase by right clicking, I... by JamalNUMAN Legendary Contributor 1 0 | 1 | 0 | |
Implemented | It would be nice to have a converter to translate .rbj file (Data Reviewer Batch Job) in ArcMap into "Attribute Rules... by PascalVezina Occasional Contributor II 1 2 | 1 | 2 | |
Closed | In ArcMap we can build regular expression checks on editable fields, and in Pro we cannot, we need the ability to cre... by TedCronin MVP Honored Contributor 0 3 | 0 | 3 | |
Needs Clarification | Hello,In ArcGIS Desktop, Data Reviewer supports the ability to edit records in a session. This isn't currently availa... by LisaBrimhall1 New Contributor III 7 5 | 7 | 5 | |
Under Consideration | Hello,In ArcGIS Desktop, Data Reviewer supports custom (user-defined) fields. This isn't currently available in Pro. ... by LisaBrimhall1 New Contributor III 6 5 | 6 | 5 | |
In Product Plan | In ArcGIS Desktop under Data Reviewer Tools, there was a tool that performed a GDB schema comparison.This appears to ... by Brian_McLeer Occasional Contributor II 10 5 | 10 | 5 | |
Open | The error management and reporting may not be being used because they rely on rules being applied to individual featu... by Anonymous User Not applicable 0 0 | 0 | 0 | |
Closed | I have seen questions on GeoNet about this, but not on the idea board. Is there a plan to allow for the creation or u... by Brian_McLeer Occasional Contributor II 1 3 | 1 | 3 | |
Implemented | When doing spatial selections, you traditionally have options like Intersect, Contains, Boundary touches, and many, m... by MartinHvidberg Occasional Contributor 4 2 | 4 | 2 | |
Implemented | With Esri support we verified that there is no way how to check following checks when need to compare feature class a... by JanBorovanský Esri Contributor 0 2 | 0 | 2 | |
Closed | Data Reviewer only allow to work on Feature Classes or Workspace.We should be able to select a stand-alone table and ... by PascalVezina Occasional Contributor II 4 2 | 4 | 2 | |
In Product Plan | I would like to be able to make a shortcut key for the command "Enter Verification Status". When using the Reviewer T... by Tine_FallemannJensen1 New Contributor II 3 2 | 3 | 2 | |
Already Offered | In Data Reviewer, as an enhancement to the Geometry on Geometry check, it would be beneficial to be able to limit the... by AndrewRudin Occasional Contributor III 4 2 | 4 | 2 |
Idea Submission Guidelines
