With the Date Selector, why is Advanced option not available with Header Panel?
555
10-09-2018 06:19 PM
WilliamRice
Occasional Contributor II
I am using Operations Dashboard in ArcGIS Enterprise 10.6.1.  When I add the a Date Selector to a Left Panel, I see three Selector Option Types:  1) Defined Options; 2) Date Picker; and 3) Advanced.  When I add a Date Selector to the Header Panel, the Advanced option is not provided.
Why is the Advanced option not available with the Date Selector with the Header Panel?
Tags (1)
GarethBaker1
Occasional Contributor III
Don't know if you've seen the note on this page of the documentation?
https://doc.arcgis.com/en/operations-dashboard/help/selectors.htm
The amount of vertical space selectors occupy on a panel can differ depending on how they are configured. Some selector configurations are not possible on the header because it has a fixed height. If you can't configure a selector a particular way on a dashboard's header, try adding the selector to the left panel or choosing a different selector configuration.
