Unable to check "data sources" to assign dynamic or static
1774
02-28-2014 04:58 AM
LarryPace
When setting up a new operations dashboard, I chose the map widget and go directly to the "Configure Map" page.  Under data sources I am not able to select the the two listed feature classes that are listed to assign it dynamic or static.  I have set up a collector
form and I am trying to set up a view for our guys.  Thanks.
LarryPace
Never mind.  Found the answer.  Feature service must be in 10.1 or later.
http://doc.arcgis.com/en/operations-dashboard/windows-desktop/author/data-sources.htm
