thousands separators in Arcade
4378
06-07-2021 08:41 AM
steffen4arcgis
I'm looking for thousands separators in Arcade to use in ArcGIS Dashboard advanced formatting option. Which code should be used? Nothing found about.
Greats,
S.Peter
jcarlson
MVP Esteemed Contributor
You'd need it to read
middleText: Text($datapoint.numbers, '###,###')
 Personally, I prefer to do any manipulation of objects and variables outside of the return statement. That way if something's not working, you can try to debug it easier. I tested this in an indicator, and it does seem to be working. I'd double-check your expression.
var some_int = 123456;
var mtext = Text(some_int, '###,###');
return {
    middleText: mtext
- Josh Carlson
Kendall County GIS
jcarlson
Try Text, maybe?
Text(123456, '###,###') -> 123,456
- Josh Carlson
Kendall County GIS
steffen4arcgis
It doesn't work. Does the number have to be formatted as text? I use the expression in ArcGIS Dashboard Indicator. --> middleText: ($datapoint.numbers, '###.###'),
numbers = integer
separator = "."
jcarlson
return {
    middleText: mtext
- Josh Carlson
Kendall County GIS
Ade_Bruijn
New Contributor III
For the users who prefer the .(period) as separator. Arcade needs , (comma) and (if I'm not mistaken) your organisation settings return a .(period)
