Stacked Map Legend
185
08-03-2021 04:30 AM
JohnKuhn
I have stacked maps in a dashboard and trying to figure out how I can insert a legend for the 2nd map (not the primary map) without the legend always being present which is the case when a side panel is used.  If anyone has any thoughts on creating a legend on the 2nd map itself please let me know.
John
KrishV
Occasional Contributor II
Hi John,
You can create another Legend for second map (You need to select, which map you want to display) and place it in your second Map.
Krish
stormy62
Thanks Krish!  Is there a way to make the Legend always show on the 2nd map with out having to click on the legend icon in the upper right corner?
John
KrishV
Hi @stormy62 ,
You can use Map Legend widget to show Legend always.
Below link is for your rference:
https://doc.arcgis.com/en/dashboards/get-started/map-legend.htm
Krish
