Showing survey123 data with Operations Dashboard
2420
02-13-2017 04:45 AM
RamiAlouta1
Hi I am trying to show on an operations dashboard how many surveys have been collected with survey123. We have a repeat function in the survey therefore one point might have more than one attribute. To show that with Operations Dashboard I added the table url as external data sources. and then created a bar graph for count of the users.
I know that I have 12 users right now collecting data but I am only able to see 2 users when I specify the Data Source as the table I have added.
Note that exactly the same survey is implemented in a different city and I followed the same workflow with the same data and I can see all my other three users in the different survey. This was all working before and then I have no idea what happened and this isn't working anymore.
Please help in case you guys know anything about this issue.
Rami
Tags (1)
RamiAlouta1
Hi all,
In case any one passed by this my problem was that the feature service I was using only supported 1000 features here is the link on how to fix this issue:
http://support.esri.com/technical-article/000012383
another post is there on this topic in case needed:
https://community.esri.com/thread/121423
