Show Field Total in Dashboard
188
06-03-2021 08:00 AM
Irena_Householder
New Contributor II
Hello. I have a field in my Survey123 (screenshot attached) that has a number value for the number of victims in each individual survey taken in our Damage Assessment field survey. I want to show, somewhere in the dashboard, the TOTAL of all victims across all surveys taken, so basically the total sum all the values in this field. I cannot find a dashboard element that will do this - I was hoping Indicator would allow me to do this somehow, but I have not found a solution yet. Is this possible to show?
Thank you!
DavidPike
MVP Frequent Contributor
Should be possible.  Add Indicator Element -> Choose your feature as input -> 'Data options' -> Statistic - 'Sum', Field - 'totalvictims' -> Done
DavidPike
Irena_Householder
New Contributor II
Thank you for your reply, this should definitely be the solution. However, this field does not show up as an option once I select 'Sum'. The question type in the survey is 'calculate' which apparently is not a numeric field. I am not sure how to format it as a numeric field which the dashboard will recognize.
Irena_Householder
New Contributor II
So I created a new integer question in the survey and that solved the problem. Thanks!
