Pop-ups not honouring dashboard filters
4229
10
05-26-2021 03:02 AM
CharlesHutchinson1
I have a number of dashboards that contain layers of survey points and extents which are stacked for multiple years. When a year filter is applied (category selector in header pane using integer as year) the pop up for these datasets in the new version of dashboards shows all records rather than those that have been filtered.
The map filter is working, with only the features for the selected year drawing but the pop-up contains records for all years. This does not happen in Dashboards Classic where only the filtered record is shown in the pop-up.
I've tried changing the filter field to a text value and also reloading all layers from scratch to check no issues casued by recent appends. This behaviour is the same on different organisational accounts for similar datasets.
Is there now somewhere that the pop-up in the dashboard map element needs to be configured to only show visible layers?
Charles
CharlesHutchinson1
Hi @JamieLambert,
thanks for the reply that's useful to know, no choice but to revert to classic then.
Charles
JamieLambert
Hi @CharlesHutchinson1,
This was a known issue before Dashboards came out of beta - first identified in late July 2020! Not sure why it was released to production with such a significant flaw. It has caused some pain...
Looks like there is BUG-000139152, BUG-000139536, BUG-000138393 (Status: In Product Plan). I can only find BUG-000138393 though.
dashboards-beta-map-widget-shows-popups-for-filtered-features
latest-update-to-arcgis-dashboards-lists-and-selectors-are-not-correctly-filtering-popups
arcgis-dashboards-beta-category-selector-filters
date-selector-in-dashboard-is-not-filtering-correctly
Jamie.
CharlesHutchinson1
Hi @JamieLambert,
Charles
ShelbyZelonisRoberson
Wow this is a HUGE issue! I just upgraded our Enterprise to 10.9.1 and now I'm getting complaints about our heavily used dashboards showing all the popups regardless of map filter. It's now February 2022... has anyone heard an update from Esri?? Do I need to re-build my dashboard in Classic?
GarethBaker1
Just ran into the same issue having upgraded to ArcGIS Enterprise 10.9.1 last month.
Think I will probably raise as a support case with ESRI UK as I might get a better idea of likely timescales for resolving (I expect they will say wait for Enterprise 11.0).
RyanStad
The new dashboards are pretty much unusable right now if you are using filters and showing popups.  This needs to be fixed ASAP please.
valenj88
ESRI please respond.
JeanetteHarlow1
Count me in on the pleading to allow filters to also control the popups.
Wondering if more emphasis is placed on ESRI innovation than solutions to problems with existing capabilities.
awgeezrick
Very true. Another great example would be for ops dashboard to honour the arcade expressions one builds in a web map. Although they say that Dashboards can use arcade expressions, much like Experience Builder, it's a super limited use (i.e. Formating (styling) for lists, math stuff for indicators). THere just seems to be a huge disconnect between the product and the end users needs. I realize that a product can't do everything for everyone, but, come on. Why wouldn't a user want to be able to use the arcade expressions they so painstakingly created in the web map not be accessible and usable in an ops dashboard, experience builder, etc.
awgeezrick
YARGH!!!!!! I too have only just discovered this huge flaw!!! If it could be fixed sooner rather than later that would be greatly appreciated. I had high hopes for 10.9.1 and all i have encountered is that while it solved some issues from 10.6.1 it now has it's own unique problems. Not really a fan of the releasing of products that still have flaws are big as this one.
