Plans to run Operations Dashboard on own IIS
1462
12-16-2018 09:57 PM
JaromHlebasko
Hello,I was just wondering if there were any plans on running Operations Dashboard on a local IIS like you can with Web AppBuilder Developer Edition?
DerekLaw
Esri Esteemed Contributor
Hi Jarom,
There are no plans to enable this type of functionality. Please post this enhancement on the ArcGIS Ideas site.
Hope this helps,
MichaelVolz
Derek:
Can you use your own non-Portal enterprise ArcGIS Server layers directly in an OpDashboard?  Or do the layers always need to pass through a portal (AGOL or your own)?
JaromHlebasko
Michael,
The dashboards have to consume a web map with services which can have ArcGIS Server layers so yes, it would have to go through ArcGIS Online or Portal for ArcGIS. We use ArcGIS Server services for our dashboards. It would be nice to host the dashboards on your local server rather than relying on Portal or ArcGIS Online.
Jarom
DerekLaw
Hi Michael,
Operations Dashboard works with "layers" - which are items found in a portal (e.g., ArcGIS Online or Portal for ArcGIS). The app does not work with ArcGIS Server web services directly.
Understand data sources—Operations Dashboard for ArcGIS | ArcGIS
Hope this helps,
