Pie Chart Labels Cut Off
2005
7
12-06-2019 07:45 AM
LeifJohnson3
Occasional Contributor II
How can I stop the labels on my pie charts from being cut off?  The Red slice should be labeled "Mammal" but the M is being cut off
DerekLaw
Esri Esteemed Contributor
Hi Leif,
This is an known issue in the pie chart element for certain size ratios.
Hope this helps,
LeifJohnson3
Thanks Derek, I've just switched it to show a legend instead of labels which seems to do accomplish the same thing.
chenry_AIR
Any chance this known issue will be fixed?
ahagopian_coj
Any update on when this will be fixed?  I am working on a dashboard for redistricting and this is driving me batty!  It will look fine on my monitor but then when I am on a big tv for presentation it will cut off the label.
ahargreaves_FW
@DerekLaw any update?
DerekLaw
Hi @ahargreaves_FW,
Unfortunately, I don't have an update to share. This is still a known issue in the Dev queue.
FYI - I changed teams a year ago and don't work on ArcGIS Dashboards, so I can't comment on when this will be fixed - sorry.
Soobin-Choi
Charting best practices should be considered to minimize issues related to pie charts' labels cropping. An example would be to stay within a reasonable and discernible number of slices (~10) so that information is communicated at a glance.
That said, we recently rolled out an update, which should mitigate, if not eliminate, any existing cropping issue on pie chart labels!
