Is it possible to edit features in the Operations Dashboard?
4553
6
09-02-2015 12:39 PM
JonathanBailey
Is there a configuration setting to make it possible to edit features from within the feature details widget or the feature popup?
KarstenRank
Hi Jonathan,
look at this discussion Editing Data in Operations Dashboard​ There is a link to a great widget.
RonKnepper
Yes, there is an edit feature widget you can add which will let you update fields or completely delete a record.
KarstenRank
Hi Jonathan,
ChrisPolley
Yes, there is a widget you can add its called View and Modify, I did have it crash my dashboard a few times but that could have been my data or the new update on Operation Dashboad. I wish to see a updated version soon.
RonKnepper
That is the problem, unless it is an official ESRI widget it may never and once dashboard updates come out it may never work so always have a backup.  I ran into an issue with an export widget which doesnt like Survery123 maps. Might never get an update so I had to figure a way outside dashboard.
ChrisPolley
Ron, what was the way outside dashboard? I might have to do or try the same thing using Survey123.
RonKnepper
Just a more conventional method, downloaded the fgdb from Survey123 (or AGOL but Survey is a little quicker to navigate to if that is all I want).  Then just export the main table data to excel and I edited a script to pull out the attachments (below).  I really like Survey123 for attachment management since you control the photo names via the fields and there is only 1 photo allowed per field so no dups.  I played with the batch export below to edit the file naming a little for my needs but it may work as is for you. Really easy to use.
41763 - Batch export attachments from a feature class
