I can't seem to create a new Dashboard without the application crashing. I tried multiple maps and it crashes with each. Anyone else having issues creating new Dashboards?
1226
02-13-2017 01:53 PM
MelanieHammond1
Every time I attempt to create a new Dashboard the program crashes. I have tried multiple maps and all fail. Below are the errors returned.
DerekLaw
Esri Esteemed Contributor
Hi Melanie,
Is this a brand new install of Operations Dashboard for ArcGIS or did you upgrade to a new release?
If the latter, was Operations Dashboard working previously?
I don't suppose you've tried uninstalling, then re-installing the software?
Some other related threads that have suggestions to help troubleshoot:
Hope this helps,
MelanieHammond1
I actually thought that could be an issue. So I went to machine which had never had it installed and did the download/install. Same problem. I will look at your links though.
