How to make public without sign in for Operations Dashboard ArcGIS Online?
3674
02-27-2018 07:22 AM
AlexP_
Occasional Contributor III
I have operations dashboard on ArcGIS Online. I set it to public on both web map and operations dashboard. It is still required to sign in to ArcGIS Online. Please advise. Thank you!
Tags (1)
Wolfgang_Grunberg_AZ_DFFM
New Contributor III
After setting all the right permissions, I had to change the organizational URL to a generic one. E.g from
http: //MyOrg.maps.arcgis.com/apps/opsdashboard/
to
http: //www.arcgis.com/apps/opsdashboard/
New Contributor III
to
JasonSmolinski
New Contributor III
This was a big help.  Thank you!
Cook_CountyGIS
New Contributor II
We had the same issue and could not figure out why, with everything shared publicly, the dashboard was still prompting for credentials.  This is the right fix for us.
However, an alternative solution that Esri recommended was to change the settings of the entire organization's AGO site to allow anaonymous access.  This is done in Organization > Settings > Security > Policies.  Certainly not what we wanted to do, but it may be an option for some.
JeffreyWilkerson
New Contributor III
We tried sending out the 'www.arcgis.com' URL to point to a dashboard, and then realized that they could see the dashboard but not all of the content.  We then updated the sharing of the Map that the dashboard was pulling from and it was working (for non-logged in users) with using just our companies ArcGIS Online URL.  We already had our settings set to allow Anonymous access though.
