How to link map to the list and the gauge
1706
02-11-2021 05:47 PM
Alexander_Valchyshen
My dashboard has three elements: (1) map, (2) list of countries, where each country is listed by size of the numeric indicator, (3) gauge element. The screenshot is attached.
I have tried to establish connections between these three objects, but I have not succeeded of a desired behavior of the dashboard. How can I set up properties of these elements so that, for example, when a user selects a country on the map both the list and the gauge show that data of that particular country?
I appreciate your support very much!
DerekLaw
Esri Esteemed Contributor
Hi @Alexander_Valchyshen ,
You can enable this type of functionality by using Actions in ArcGIS Dashboards. Please review the online help topic: https://doc.arcgis.com/en/dashboards/create-and-share/actions.htm
In your case, you would configure an operational layer in your Map element to trigger an action on the other elements. I would add a Details element to the dashboard, so when a user selects a country, this will apply a filter action on the Details element to show more info about the selected country. I believe you could also set a filter on the Gauge element as well.
Hope this helps,
Thank you very much!
