How to create Pivot Table like MS Excel in ArcGIS Dashboard
4104
5
06-12-2023 06:33 AM
HunarSaleem
I have big Excel sheet table, contains province (16 provinces A, B, C, D.....etc) and a column name Status. The Status has many categories like ( Canceled, Completed, Extended, Initiated, Issued, Ongoing, Suspended ).
In the ArcGIS dashboard I need to create a table like below:
Province Canceled  Completed  Extended  Initiated  Issued  Ongoing  Suspended  Grand Total
A66139550183113              457
B511102021                 40
C132500700                 45
D36529107316320           1,308
E1337003900                 89
F22551108813              180
G010001200                 22
H31306001540              293
I2571000660              135
J611001600                 33
K1423315143311825              902
L21300710                 23
M21639174101              179
N558100230                 87
W639202700                 74
Grand Total              342          1,508              253                  8              805              918                33           3,867
How can I do that in ArcGIS Dashboard, please your support.
The Excel sheet is in the attachment file.
JoseBarrios1
Hello HunarSaleem
There are several ways to accomplish this on the current AGOL Dashboard platform.
1) use the table widget on dashboard. In table type, pick features (instead a grouped vales) and add your fields.
2) if the table is not too big, you can just copy and paste the table into a  "Rich text" widget and edit  layout with html/css.
3) if the table is big, you can also create the table using the "list" widget and enable arcade/html to build the table
4) the easy way will be to lunch the Experience builder app a create a page with your table (Exp. Builder does have a nice table widget) and use the "embedded content" widget in dashboard to bring the Exp. Builder table.
HunarSaleem
Thank you JoseBarrios1 for your reply and suggestions, I already try all these ways that you suggested, but it doesn't gave me what I want. See the Excel file that I attached, and look at the result (Just like Excel Pivot Table) that I mentioned in my message. I want to be my table just like I illustrated.
Any other suggestions, please?
MHami
Did you ever find a solution to this?  I'm trying to do the same thing.  Thanks!
Katie_Macintyre_Atmos
I'm trying to do something similar with breeding bird territories. I'd like to summarise by species and breeding status but the grouped values option only gives the total count per species and doesn't allow the count to be split by the breeding status field. The features option suggested above doesn't give the total counts, just the features values themselves
JoseBarrios1
The standard ArcGIS Online Dashboard “Grouped Values” only gives totals per single field, and “Features” just lists each feature — so you need to use a data expression (Arcade) to create the summary table. Screenshot 2025-11-21 093242.pngScreenshot 2025-11-21 093242.png
Arcade:
// Load the layer
var fs = FeatureSetByPortalItem(
    Portal('https://www.arcgis.com'),
    '70f5d3269a...your ID',
    0,
    ['Province', 'Status'],
    false
// Get distinct values
var provinces = Distinct(fs, 'Province');
var statuses = Distinct(fs, 'Status');
// --- Build dynamic fields list ---
var fields = [
    { name: "Province", type: "esriFieldTypeString" }
for (var s in statuses) {
    Push(fields, {
        type: "esriFieldTypeInteger"
// Add grand total column
Push(fields, {
// Build schema
var schema = {
    fields: fields,
    geometryType: "",
    features: []
// Track totals for each status across all provinces
var overallTotals = {};
// Initialize overall totals
    overallTotals[s.Status] = 0;
// --- Loop through provinces and build rows ---
for (var p in provinces) {
    var provName = p.Province;
    var attrs = { "Province": provName };
    var rowTotal = 0;
        var statusName = s.Status;
        var cnt = Count(
            Filter(fs, "Province = @provName AND Status = @statusName")
        attrs[statusName] = cnt;
        rowTotal += cnt;
        overallTotals[statusName] += cnt;
    attrs["GrandTotal"] = rowTotal;
    // Push row
    Push(schema.features, { attributes: attrs });
// --- Add GRAND TOTAL ROW ---
var finalRow = { "Province": "GRAND TOTAL" };
var finalSum = 0;
    var totalStatus = overallTotals[statusName];
    finalRow[statusName] = totalStatus;
    finalSum += totalStatus;
finalRow["GrandTotal"] = finalSum;
// Add to the table
    attributes: finalRow
return FeatureSet(schema);
