How do you change date format to dd-mm-yyyy?
4645
7
03-15-2021 12:50 PM
Anneka_France
The date on our dashboards is appearing in the US format mm-dd-yyyy, even though we are in the UK and the system locale is set to en-GB. Is there a way to change the date format to UK dd-mm-yyyy?
Anneka France
Technical Manager at The Rivers Trust
CraigRussell
I tested this in AGOL and found that when number and date is set to Great Britain - Great Britain in my profile, I do in fact get US date format:
This appears to be a bug.
However, if you change the number format to Australia - Australia, you should get the correct date format:
Maybe try this and see if it is a workable solution in the interim?
CraigRussell
Hi Anneka
Is the number and date format set to Great Britain in your organisation settings, as well as for each user?
Organization > Settings > General
Organization > Members > View Profile > Settings:
Cheers
Craig
Anneka_France
Hi @CraigRussell,
Yes, our organisation default language is set to English - English and number and date is set to Great Britain - Great Britain. We've checked our individual profiles and they are also using the same settings. We've even made sure that the date is in UK format in the layer pop ups, but no luck.
When logged in or out on different devices the date still appears in US format. Is this a bug? It is essential that we can change the date format in our dashboards to avoid confusion for our British and European users. If the dashboard cannot automatically update the date settings based on the users locale, then there should be a setting to override this or the date should be shown in written format e.g. 16th March 2021.
Thanks for your help
Anneka France
CraigRussell
PeterKT
We've had an AGOL organisation for years and no matter what we do it's sticks with US date formats.
"Number and Date Format" in both organisation and profile set to "Australia - Australia" and it still results in mm/dd/yyyy .
It's now still happening in the beta dashboard.
Even if mmm dd yyyy was offered.....
Beta dashboard list  (7 April)
Peter T, Brisbane
Anneka_France
Hi @CraigRussell
That solution works in the meantime. Has this bug been logged and do you know when it will be resolved?
Thanks!
Anneka France
CraigRussell
Hey Anneka
You should log this with your local support provider, then you'll get updates on resolution timeframes etc.
Craig
DebSF
@Anneka_France Did you ever get this resolved/logged as a bug? I'm having the same issue - date is set everywhere on my laptop, browser and AGOL as UK, but dates in pop-ups, dashboards etc showing as US format.
I've just tried the workaround to changing to Australia and it's showing in the correct DD/MM/YYYY now, but ideally wouldn't need to do that!
