Help with Dashboard Date Range Selector
2441
7
04-14-2021 05:19 PM
MayraHernandez
New Contributor III
Hello,
Can someone please help me out with the dashboard date selector tool.  Not sure what happened...I created a dashboard a couple weeks ago. I added the date selector so that users can select a range and according to the date they chose certain data will display on the map.
I looked at the dashboard today and the date selector is different. I have to manually enter the date range...It is not possible to click on the calendar to choose a start and end date. This will be confusing for the end users...
The date range selector is really essential for this particular dashboard.
This is how the date selector was displayed before: MayraHernandez_1-1618444469476.png
This is the date selector now. We can no longer click on the calendar to choose the start and end date.
Corona Shopping Cart Retrieval Program (arcgis.com)
2 Solutions
SandraLuken1
Hi Mayra,
The date range can be selected by first clicking the start date and the holding the shift key while clicking the end date. Then you can click outside the calendar to dismiss it when finished with the selection.
SandraLuken1
And using the Shift key to select the upper date range is not working? First click the start date and then hold the shift key and click the end date. Then you can click outside the calendar to dismiss it when finished with the selection.
SandraLuken1
Hi Mayra,
MayraHernandez
New Contributor III
Hi @SandraLuken1, thank you so much for your response! I will relate this back to my team.
AfafAbbas1
Hi Sandra,
Hello, this is what happened to me too. I had a dashboard created few months ago and the clients are using it regularly. I opened the dashboard for editing today and found out the date selector has changed. I can no longer able to pick a date, the date show two range but just one of respond to the date selection, even if I click on the lower date and select a date from the calendar, the date gets changed on the upper date window. see the below snapshots. this tool is crucial to our client day to day work. any help is much appreciated.
Only the highlighted date respond to the calendar's date selection
SandraLuken1
AfafAbbas1
Thanks heaps Sandra, I wasn't aware of the shift key thingy, I guess this is a new configuration to the date selector.
it is working like a charm now!!! thank you
MayraHernandez
New Contributor III
Hi @SandraLuken1, we noticed that one of the layers (Heat Map) does not change when we select a date range. The layer is included in the date selector actions section.  Do you have any tips on how to fix this?
SandraLuken1
This is a known issue with ArcGIS Dashboards, and other JSAPI 4x based applications. This will continue to work with ArcGIS Dashboards Classic (found in the app launder). You can contact Technical Support to be added to the bug and be notified when it is fixed.
