Find Point that near route
189
04-19-2025 07:04 AM
HingFungChan
I have a Point layer and a Route layer,
I would like to show only the nearest point near the route,
How can i do that?
Louis-VincentGrandMaison
You seem to be working with Arcgis Online, so here is how you can do this:
  1. Open the Analysis tab
  2. Search for the "Find Closest" Analysis
    • Input Layer: Select your Point layer.
    • Near Layer: Select your Route layer.
    • Maximum Distance (optional): Set a distance threshold to limit results.
    • Count of Nearest Locations: Set to 1 (to find only 1 closest point per route segment).
      • You can also find multiple points by adjusting this parameter
  3. Click Run Analysis.
  4. A new layer is created showing only the nearest points. You can then modify the visual aspect however you wish
Alternatively, you could prepare the data in Arcgis Pro beforehand and then visualize it on Online, if you are more familiar with that. The process is very similar, just use the Near analysis tool instead.
