FeatureSetByPortalItem - Picking an Enterprise Portal?
737
5
06-07-2023 05:08 PM
ghaskett_aaic
I am trying to build a new data expression in a serial chart within my ArcGIS Dashboard app using FeatureSetByPortalItem().
I can create one connecting to my AGOL account, however I don't seem to be able to create one connecting to my local Enterprise Portal account.  When I try I get the following error message:
Execution Error:Item does not exist or is inaccessible.
From what I can read via: https://developers.arcgis.com/arcade/guide/types/#portal
I should be able to connect to a service via its service ID.  The service exists, but I am not able to connect to it.  Right now the service is shared with a Beta Testing group within our Portal.
Is there a chance my share settings are blocking it?  I am an admin and member of said group.  I have tried both the default 'www.arcgis.com' and the URL for my Enterprise Portal.
Any ideas?  Thanks
var p = Portal('https://www.arcgis.com');
var features = FeatureSetByPortalItem(
  p,
  'xxxxxxxxxxxx',
  0,
  false
Count(features);
jcarlson
The URL must be the portal's URL, i.e., https://maps.co.kendall.il.us/portal would be mine.
If you're trying to access a service that is not shared publicly, it should prompt you to log in. Where are you running the expression, AGOL or your portal? Is the layer shared?
- Josh Carlson
Kendall County GIS
ghaskett_aaic
Thanks.
I am running the expression via an ArcGIS Dashboard on our Enterprise Portal.
The service in question is shared within our organization.  I am an admin for the organization as well.
I updated the script as you have shown and now it seems to be working.  Thanks!
So the next step is how do I go about intersecting 2 services and creating a new summarized feature set to capture the number of point features within intersecting polygons?
jcarlson
Spatially intersecting two layers works the same, regardless of where the two layers come from. Here's a rough idea of what this would look like, though you'll need to make some adjustments.
var p1 = Portal('portal-url')
var p2 = Portal('agol-url')
// your portal fs; i'm assuming that this is the polygon layer
var fs1 = FeatureSetByPortalItem(
    p1,
    'itemid',
    0,false
    ['objectid'],
    true
// your agol fs
var fs2 = FeatureSetByPortalItem(
    p2,
    'itemid',
    0,
    ['objectid'],
    false
// output dict
var out_dict = {
    fields: [
        {name: 'polygon_id', type: 'esriFieldTypeString'},
        {name: 'point_count', type: 'esriFieldTypeInteger'}
    geometryType: '',
    features: []
// loop through polygons, get points
for (var f in fs1) {
    var xs_pts = Intersects(f, fs2)
    Push(
        out_dict['features'],
            attributes: {
                polygon_id: f['objectid'],
                point_count: Count(xs_pts)
return FeatureSet(Text(out_dict))
- Josh Carlson
Kendall County GIS
ghaskett_aaic
Thanks again for your help on this.
I updated my script to the following and while the returned numbers seemed valid when testing, the return lacks information in the SIZE and RISKCNT fields.
What am I doing wrong?
var p = Portal('https://maps.xxxxx.com/portal/')
var sql = "(DATE > CURRENT_DATE - 7)"
var sqlST = "(STATE = 'CO')"
// the polygon layer
var fsHail = FeatureSetByPortalItem(p,
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
0, ['label', 'SIZE', 'DATE_TEXT'], true
var fHail = Filter(fsHail, sql);
// the pts layer
var fsInforce = FeatureSetByPortalItem(p,
0, ['PolicyNumber', 'LocationID', 'LOB', 'TIV', 'RiskCount'], false
var fInforce = Filter(fsInforce, sqlST);
/*Count(fInforce);*/
// output dict
var out_dict = {
    fields: [
        {name:'SIZE', type:'esriFieldTypeInteger'},
        {name:'RISKCNT', type:'esriFieldTypeInteger'}
    geometryType: '',
    features:[]
for (var f in fHail) {
    var xs_pts = Intersects(f, fInforce)
    Push(
            attributes: [
                    RISKCNT: Count(xs_pts)
jcarlson
attributes is a dict, not an array, and I realize I had that wrong in my expression.
It should be:
attributes: {
I will update my post accordingly.
- Josh Carlson
Kendall County GIS
