Editing Data in Operations Dashboard
15797
16
08-14-2014 06:35 AM
JordanRogers
New Contributor III
I was just wondering if there has been any consideration given to adding an option to allow the ability to edit data within Operations Dashboard?  Or, if anyone knows of a possible add-in that would allow this?
I am looking at setting up an Operations Dashboard for a Supervisor to monitor field edits from Collector.  Ideally, I would like to give the Supervisor the ability to edit some of the attributes in Operations Dashboard rather than using it to monitor and opening a separate web map to edit.
For example: if something is flagged as 'Needs Attention', the Supervisor would have the ability to assign a 'Work Order ID' and later change the attribute to 'Resolved'.
MarcoWagemakers
Hi Karsten ,
Here you go, the addin file is the data property in the item:
http://www.arcgis.com/sharing/rest/content/items/0df06e8b8bb04e0395d5e3ccce9a2a14/data
Marco
KarstenRank
Occasional Contributor III
Hi Marco,
the addin is great! Thanks a lot for it.
Karsten
RichardFreer2
New Contributor II
I've been trying to access the first link for view/edit attributes widget, but its says I don't have permission to view.  Is this for Web App Builder and not Operational Dashboard?
RickeyFight
MVP Regular Contributor
I just want to confirm that there is no way to edit in operations dashboard in a browsers?
I don't want to make another application or site that our users have to go to just to edit info.
ChristopherOlsen
There are no built in widgets that allow direct editing of data in Operations Dashboard.
However.....
The above discussion is on a user built widget that would allow it in the desktop version of Ops Dashboard.  In order for this widget to work in a browser, it would need to rebuilt in JavaScript and hosted in AGOL or Portal. Then you could have editing within the browser Operations Dashboard.
AliAsgary1
Hello,
I added the View/Edit Attributes widget successfully, but when I try to add it to my Dashboards, it stops working and I have to close the program. Any ideas why this might happen?
AndreDu_Preez1
Hi Marco is there a download available for Extract data.
Please
