Combining categories in Operations Dashboard
662
09-25-2020 06:32 AM
865_FCGIS
New Contributor II
I am attempting to create a Yes/No category selector based on if an inspection is a municipal inspection vs. all other inspection types. The issue I'm having is the source data table has multiple category names that I a trying to combine into one "No" selector and I am not seeing a way to do this in the category selector. The best I have been able to do is change the label of every category that is not "Municipal" to "No" but that results in 10 separate "No" buttons in the selector (see attached).
Is there a way to create a combined category without adjusting/adding a new field to the source data?
MeredithDutlinger1
New Contributor III
curious if you ever found a solution for this?  same issue here!
