Changing colour of Pie cart
1681
01-07-2020 11:41 AM
MuhammadYasir
Hi there,
I followed the article (Operations Dashboard: ) to improve the visualization of Pie chart. I ended up showing three categories on the pie chart. However, all three categories have the same colour. When I tried to change the colour of each category, it only changed the colour of the "other" category. It didn't change the colour of the remaining two categories. I attached the screenshot of slices tab of the pie chart. Any help to fix the issue would be appreciated.
Tags (1)
DavidNyenhuis1
Hi Muhammad,
It looks like the colors per category/slice are not defined in your screenshot. Try pressing "Load Categories" to auto-generate colors. If this doesn't work (e.g., if you have too many categories in your data) or you'd like to add just the categories shown, click the "+ Category" button and enter the string values of each category you'd like to define a color for.
MuhammadYasir
Hi David,
Thanks for the reply. I pressed "Load Categories" multiple times. I think I have too many categories. I can't enter the category manually as it changes according to different scenarios. Any other suggestion????
