Cannot Access Data with Gauge element in Dashboard in ArcGIS Online
1707
05-21-2021 06:58 AM
by Anonymous User
Not applicable
I am trying to create a dashboard that references data in an enterprise geodatabase to monitor our progress as the data is edited. But, when I use the data as a source for the Gauge element in the Dashboard it says "Cannot access data" and the "Loading Data" keeps spinning. I need help figuring out why.
The source data is layer from a map service in ArcGIS Server. The map service was published to reference source a feature class in an enterprise geodatabase. The map service has other layers as well and those work just fine in the Gauge element of a dashboard.
Some additional information/troubleshooting I've tried:
1. I can click show preview of the data and it shows the data in table form
2. The map service that the data is in has other layers, if I use those layers as a source for the Gauge element they load just fine.
3. If I publish the feature class as a hosted feature service in ArcGIS Online the Gauge will work. But, I don't want the data source to be a copy in ArcGIS online, I want it to reference the original data from the enterprise geodatabase.
4. The data works with other elements, like the List in the dashboard.
I have a feeling it is something specific about how the Gauge element queries the data that isn't working with this layer in the map service. But, can't figure out what.
by Anonymous User
Not applicable
Closing the loop on this issue in case its helpful to anyone in the future.
I checked the ArcGIS Server logs when the Gauge element produced "Cannot Access Data" and it recorded the following error:
    • Geodatabase error: Insufficient permissions[42000:[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]The SELECT permission was denied on the object 'XXX_evw', database 'XXX', schema 'XXX'.]. Insufficient permissions.
Turns out the arcgis server user had permissions to the feature class in the enterprise geodatabase, but not the versioned view. In ArcCatalog, I regranted SELECT privileges on the feature class to the arcgis server user and now I can used the Gauge element with the layer.
by Anonymous User
Not applicable
