Can I use ArcGIS REST-API "applyEdits" to update Feature-Layer as an authenticated user?
523
11-10-2021 11:24 PM
Adeelnikama
I'm using nodeJS to edit my Feature-Layer using REST API. My intention is to:
  1. Update my layer using Firebase Cloud-Functions
  2. Share my layer publicly
  3. But keep my layer non-editable for unauthorised users
  4. I want to use my API-Key for authentication.
My problem: If I edit my feature definition to "capabilities" : "Create, Update, Delete" as mentioned here, then any unauthorised user can edit my layer, while if I don't, I get:
[ 'This operation is not supported.', 'Unable to add the features.', 'This operation is not supported.' ]
Authentication is declered in the documentation.
My code:
require("cross-fetch/polyfill");
require("isomorphic-form-data");
const featureLayer = require('@esri/arcgis-rest-feature-layer');
const auth = require('@esri/arcgis-rest-auth');
const apiKey = new auth.ApiKey({key: 'some key...'});
featureLayer.applyEdits({
    url: "https://services3.arcgis.com/someID/arcgis/rest/services/someName/FeatureServer/0",
    adds: [{
      geometry: { x: 120, y: 45 },
      attributes: { indexCity: "alive" }
    authentication: apiKey
    .then(response => {
      console.log(response)
    .catch(err => console.log(err.response.error.details));
I'm running my code using node example.js in terminal.
