Calculate percentage for all features
1439
08-01-2021 11:54 PM
OfraAi
I have data about Covid 19 per city, per day.
Some of the measures are calculation of sick percentage of all population, percent of positive tests and so on.
For example: pctSick = sick / population
I need to calculate these measures in other levels then cities, like region and all country.
The right calculation should be sum(sick) / sum(population), while the data is filtered by the city/region/country.
The only option I see in dashboard is calculating avg(pctSick) which is not correct.
How can I define the right calculation, and use is in indicators and graphs?
Thanks in advance
Ofra
OfraAi
Hello,
I've made some progress.
In Indicators, I've found that I can define in Data tab: 'value' as sum over sick, and 'reference' as sum over population.
In Indicator tab: Advanced formatting, I enabled the expressions.
There are already several definition of calculations, and one of them is 'ratio'.
I only had to use this variable as the middleText and it works very good.
When I filter the dashboard, these values a also filtered (after defining them in the action of the category selection off course).
Now I need this calculation in a chart...
Any idea how to define the arcade expression the will do the summarize and division, and still have the city to filter by?
Any help would be very appreciated.
Ofra
