ArcGIS Operations Dashboard Arcade Join Table
3411
6
01-04-2022 07:56 AM
Norchevskyi
I'm trying to create Arcade Expression, that will join the feature layer and a feature table for different widgets in Operations Dashboard, but my expression cannot load the data, please help me, as I suspect that something was not provided for in the code of this expression.
var portal = Portal("https://www.arcgis.com/");
var polyfs = FeatureSetByPortalItem(portal,"2c70f00e262a4488b266595720312617",0,["*"],true);
var tablefs = FeatureSetByPortalItem(portal,"227503e1ba6848baa7227b6311c04802",0,["*"],false);
var joinedDict = {
  fields: [
    { name: "StreetID", type: "esriFieldTypeInteger" },
    { name: "Name", type: "esriFieldTypeString" },
    { name: "Depth", type: "esriFieldTypeFloat" },
'geometryType': '',
'features':[]};
var i = 0;
for (var t in tablefs) {
    var tableID = t["StreetID"]
    for (var p in Filter(polyfs, "StreetID = "+tableID)){
        joinedDict.features[i] = {
            attributes: {
                StreetID: tableID,
				Depth: t["Depth"],
i++
return FeatureSet(Text(joinedDict));
Thank you,
Roman
jcarlson
Ah, I see it now. You are trying to cast the Depth as a "float", which isn't in the list of field types you can use (even though it is a valid data type in other contexts).
Change that to 'esriFieldTypeDouble' and it evaluates just fine:
- Josh Carlson
Kendall County GIS
jcarlson
I would guess it has something to do with that Filter statement, but since the layers aren't shared publicly, it's hard to say for sure. Usually when referencing a variable in your expression string, you should put it in the string itself in the format @variableName. Try this to see if the output changes.
var i = 0;
    var filt_poly = Filter(polyfs, "StreetID = @tableID")
    for (var p in filt_poly){
            attributes:
                StreetID: tableID
                Depth: t["Depth"],
i++
- Josh Carlson
Kendall County GIS
Norchevskyi
Hi Josh,
Thanks for your answer, I applied your recomendations, but it not working. When I click Test button, I don't see error:
But after click Done button I see error in the expression:
I shared this services as public for everyone,
Thank you,
Roman
jcarlson
- Josh Carlson
Kendall County GIS
Norchevskyi
Josh, thank you very much, it is working
Roman
RussellLundstrumUSACE
A follow up question to data types- when I try to define a date, there is not an error, but nothing is returned. Example below I modified from github here
I added lines 33 and 48 to get the ForecastTime which is a date field in the source, but when it is defined as "esriFieldTypeDate" in line 48, the Test fails. If you change it to "esriFieldTypeString" it works. But I want to have a date type to work with in the dashboard. Are dates not supported or am I missing something else?
    portal,
    "4dbbad3d6f694e0ebc7c3b4132ea34df",
    0,
    false
    portal,
    6,
    false
// Create empty features array and feat object
var features = [];
var feat;
// Populate Feature Array
    var tableID = t["FeatureID"]
    for (var p in Filter(polyfs, "HydroID = "+tableID)){
        feat = {
            attributes: {
                FeatureID: tableID,
				ModelID: t["ModelID"],
                AddressCount: t["AddressCount"],
                MAX_TSTime: t["MAX_TSTime"],
                ForecastTime: t["ForecastTime"],
    Push(features, feat)
var joinedDict = {
    fields: [
        { name: "FeatureID", type: "esriFieldTypeString" },
        { name: "ModelID", type: "esriFieldTypeInteger" },
        { name: "AddressCount", type: "esriFieldTypeInteger" },
        { name: "MAX_TSTime", type: "esriFieldTypeString" },
        { name: "ForecastTime", type: "esriFieldTypeDate" },
    'geometryType': '',
    'features':features
// Return dictionary cast as a feature set
EDIT: I found help from a co-worker- added number() in the attribute array on line 33 above:
ForecastTime: number(t["ForecastTime"]),
Manager_HMWSSBCDC
var item_id = '99646c55510049a583bc1fe853c7f5f0';
var fields = ['docketcode','objectid'];
var tankers_table = FeatureSetByPortalItem(portal, item_id, 4, fields, false);
// return tankers_table
var item_id2 = '7a28dc5aad08489ea8ce46f8eeedb51e'
var fields_2 = ['fs_name','docketno','objectid']
var fs_table = FeatureSetByPortalItem(portal, item_id2, 6, fields_2, false)
// return fs_table
var joinedDict = {
  fields: [
    { name: "docket", type: "esriFieldTypeString" },
    { name: "fsName", type: "esriFieldTypeString" },
'geometryType': '',
'features':[]};
var i = 0;
for (var t in fs_table) {
    var tableID = t["docketno"]
    var filt_tanker = Filter(tankers_table, "docketcode = @tableID")
    for (var p in filt_tanker){
            attributes: {
                docket: tableID,
                fsName: t["fs_name"],
i++
Error message i'm getting is
Test execution error: Execution error - Out of bounds. Verify test data.
Please help me to find where the error was.
