ArcGIS Dashboard Selectors Searching Across Multiple Fields
374
04-04-2025 07:45 AM
Landen_L
I'm reaching out here because I'm currently stuck and hoping to find some guidance.
I'm building a dashboard where the end user will be able to filter multiple fields to suit their needs. The issue I'm running into involves a field setup in my ArcGIS Pro project. I have a "Sub-Type" section that currently spans across eight different fields (e.g., Sub-Type 1, Sub-Type 2, etc.).
The challenge is that the Category Selector in the dashboard only allows filtering based on a single field, rather than across multiple fields. This becomes problematic because depending on the polygon, a specific attribute—like "Servicing"—might appear in Sub-Type 1 for one feature, and in Sub-Type 2 for another.
There are around 40 sub-types in my domain, and I'd like users to be able to search for any sub-type value (e.g., "Servicing") regardless of which sub-type field it's in. As it stands, the Category Selector will only search within Sub-Type 1, which severely limits its functionality.
Has anyone dealt with a similar situation, or does anyone have suggestions for how to approach this? I'm open to restructuring my data or using Arcade if that helps. I have attached a screenshot of my current category selectors in my dashboard.
Thanks in advance!
