ArcGIS Dashboard - out of memory
1210
03-01-2021 04:44 AM
nataliesef
Hi, I'm creating a dashboard with layer including more than 700 000 features. Map, pie chart, gauge and other components are loaded quickly, but then in a few seconds an error out of memory appears. Can I fix that anyhow? Do you think Dashboard is not able to work with so big layer?
RobertBorchert
Honored Contributor
You need to set visibility settings for your features.  You are most likely exceeding the Maximum Number of records returned by server, for your feature service.  By default that is set to 2000 records when you publish a service.
