Arcade data expression: match IDs from two feature sets (join fields, 1:1)
899
09-22-2021 05:02 AM
Merlin
New Contributor III
Hi there,
this time I have a question that might be a bit tricky: how can you loop through a featureSet (fs1) and check each time if the current ID is found in another featureSet (fs2)?
I basically try to achive a join field operation from ArcGIS Pro.
To illustrate:
I want to loop through fs1 containing IDs:
and for each ID in the loop, I would like to see if there is a matching ID in fs2.
My initial idea was to have a first for loop to move through the rows of fs1 and then have a second for loop nested within the first, which could pick up the current ID value and loop through fs2 to find a match. But I didnt manage to make nested for loops pointing at different featureSets working.
Any ideas?
Thanks in advance,
Merlin
JohannesLindner
MVP Frequent Contributor
var fs1 = FeatureSetByName(...)
var fs2 = FeatureSetByName(...)
for(var row1 in fs1) {
  var id1 = row1.FFGId
  var filtered_fs2 = Filter(fs2, "FFGId = @id1")
  for(var row2 in filtered_fs2) {
    // do stuff
Have a great day!
Johannes
