Action from a list to be propagated to embeded dashbords
1561
6
07-20-2023 02:48 AM
LMBaptista
Hi, all. Any help will be greatly appreciated.
I have a dashboard with another embeded dashboard. When I select a record from a list I configured the actions to filter other widgets, but I can't do it to the embeded dashboard.
Maybe I can use parameters, but can't find how.
Any solution for this in Operations Dashboards?
Thanks in advance
JenniferAcunto
You need to set your embed as a feature and select the layer that drives it and not add it as a static embed.
Embed Widget:
List Widget:
- Jen
JenniferAcunto
You would need to set up URL parameters on your embedded dashboard.
Configure Actions on URL Parameters
Then you would need to set your embed widget to feature and add your child dashboard URL with the URL parameters and the reference field from your parent dashboard that provides the parameter value. It will look something like this: https://<myorg>/portal/apps/dashboards/<itemid>?state={state}
- Jen
LMBaptista
Hi, Jennifer, thank you for the tip, but I can't find where to set them.
I created the URL parameter in the Dashboard 2 (the one to embed) called state. The field is {state} also.
In dashboard 1 I added the dashboard2 as embedded content. I think this is the only place where I can define anything.
I used the link of dashboard2 (so it can appear) with the parameter just like you mention:
But with this configuration the dashboard does not appear, keep circling around waiting for something that never happens.
What am I missing?
JenniferAcunto
Do you have an action set up to control the embed widget and have you made a selection? Because you are using URL parameters - the URL to the embedded dashboard will only work once you have a parameter value. Your parent dashboard is not sending it a parameter value until a selection has been made.
I would recommend having a list drive the embed and setting it to 'render only when selected' so that it only displays once a user picks a list item.
- Jen
LMBaptista
I think that's the point. The embedded content does not appear as a possible target when I'm defining the action (Filter) from Dashboard1 to Dashboard2.
JenniferAcunto
Embed Widget:
List Widget:
- Jen
sandra555
Thanks Jen for your post with the screenshots - those were really helpful for me.
For others struggling to get this to work, for me, the form of the URL was different then noted above, it was like this: https://www.arcgis.com/apps/dashboards/32d0fdf612b440a3ttt9437077693e02#site_no={field/site_no}
Where the first site_no is the name of my URL setup in my embedded content and the {field/site_no} is the field in my main dashboard that is changing.
