A lot of my serial charts in Dashboards look slightly different today
671
10
06-27-2024 07:35 AM
BryanWright
Just wondering if there were any updates to the serial chart element in Dashboards in the last couple days?  I'm noticing a lot of small changes in the way my serial charts are being displayed across multiple dashboards.  For example, I had a serial chart that used to be sorted by a statistic, but now that statistic doesn't even show up in the sort drop-down list.  I'm also seeing lots of changes to labels.  For example, instead of a label for every variable level on the category axis, now its only displaying every other level.  In another case, I have guide labels set to render above the chart but they are now rendering below.  Again, this all just changed in the last 1-2 days with no changes to underlying data or anything else I'm aware of.
2 Solutions
Stephanie_F
Hi Bryan, ArcGIS Dashboards updated last night with ArcGIS Online. Highlights are outlined in their What's New page.
If you are seeing unexpected behavior with your Dashboards, I recommend working with Technical Support to investigate.
Soobin-Choi
Hi all, we deployed a fix to improve the display of serial chart labels a few hours ago. Appreciate your feedback and patience!
LuisBaena1
In our case we see that in the series graphs in which "Divide by field" is used, they stopped showing data.
Bruno_DiegoCardoso
We are having the same error here in all our applications. This messed up our graphics overall. We can no longer divide the field or sort by statistics anymore. This new update is so bad
NadinaSchlik
Hi Bruno! Could you provide more information about your issue? When using Split by field the chart shows "cannot access data"?
We are experiencing the same issue as Luis. In our case, it only happens with referenced layers to a 10.8.1 server, not with hosted ones. Thank you!
Stephanie_F
Joel_Lopez
Ditto. All labels on my serial charts will not display even after several different configuration attempts. They were displaying fine before the update.
kstone_ntia
I am also having this issue with the serial chart labels.
Esri - if you are able to fix this issue please post here.
Thanks.
Soobin-Choi
Hi there, I would suggest trying a different category label placement option to see if the rendering improves.
If you encounter any issues or have specific requirements, please reach out to Esri Technical Support for assistance.  
CharlesHutchinson1
Hi all,
ditto to above, category axis in dashboard charts behaving differently, mainly ticks and labels have become very sparse some charts only 1 label for several years, others labels now taking up half of chart area.
Also unable to access configuration menu for most maps within dashboards.
Soobin-Choi
