I have two serial charts set up to filter each other (*hint*due to a lack of dual-axis option*/hint*), so that when I select a timerange in one chart, it filters the same timerange in the other chart.
The first chart remains un-filtered however. Is this a bug, or not a feature?
In case of the latter:
My question about this being a bug is due to the chart being able to filter itself the second time you filter;
Filter Chart 1 (chart 1 doesn't change), then Chart 2. When you filter Chart 2 it will actually filter itself as expected, probably because of the filter action from chart 1 but then that should also be the case when you filter the first time.
See GIF attachment.
To reset both charts I have to click each chart in the correct order to reset the filter-action, but this is not user-friendly for the end-user.
What platform and version are you using?
ArcGIS Online and the september 2021 release.
