Hi @StuartMoore , there already is a data download option which you can toggle on to allow for the export of the dashboard element into a csv file.
https://doc.arcgis.com/en/dashboards/create-and-share/download-data.htm
Hope this helps!
thanks @EmilyMcLeanACTGOV i didn't know that the option already existed for hosted layers, just done some testing and yea it works just needed to enable download in the feature service and also in the dashboard element settings 🙂
it doesn't work for data sources which are arcade data expressions which is a shame
thanks Stu
