Export and Import Operations Dashboard
2763
09-27-2020 08:40 PM
Status: Open
ABHISHEK_SINDAL
New Contributor III
It is a need of the hour that there should be a functionality to export configured Operations dashboard (say in xml) and to import with necessary modifications (service urls etc.) in other PFA / AGOL account. Otherwise, it needs to be reconfigured, in case there is a change in PFA / AGOL account.
Tags (1)
4 Comments
SantanuDutta
Yes...this is very much required..
RaúlDíaz_Luna
It is the same need we have when using a dashboard, at least one screen capture option that can be downloaded, sent or shared. As well as being able to incorporate the same widget for viewing and exporting the data to csv.
MitikaGarg
Yes , it is really helpful functionality and it will help reducing the efforts also for migrating the same on another site enable the re usability.
davedoesgis
You can already do this. The JSON that defines it is available via the arcgis API or the AGOL Assistant. You can modify that and use it to create a new dashboard with the arcgis API.
