Hi All,
I know that we are currently able to load category from the map layer. It will be very powerful if the color codes of the category of serial/pie chart can utilize the filled/line/point color of the target map layer. It will create some great consistency between layer symbology and category color codes.
Cordially,
Reno
I ran into this, and I also tried to change the colors manually, but they're not reflected on the left chart.
Also, why don't the fields on the right side pull in sorted by the map like the left side?
