Dashboards often appear differently once they are embedded in Story Maps with regard to labeling. Often labels in legends, axes, and pie chart slices are cut off (either do not appear at all or require scrolling to be visible) in Story Maps that are completely visible in dashboards. One must continually switch between the dashboard configuration webpage in one tab and the Story Map webpage in another tab to see what edits to the dashboard will ultimately look like in the Story Map. It would be nice to have the ability to view what the dashboard would like embedded in the Story Map in the dashboard configuration webpage without having to continuously switch tabs and refresh the Story Map.
