Rather than creating several panes, or widgets, sometimes we'd like to just choose between a value, or set of values to display on our dashboard. Right now, the ability to change filter values, such as date ranges, text fields, ect can only be set when the dashboard is being edited. At the moment, our only option is to create dashboards using the Web App Builder, which can take much longer to put together, and isn't quite as streamlined for some of our publishers.
@MatthewBradbury Some of what you're trying to achieve can be done with url parameters and actions that respond to url parameters. Changing which field a data visualization uses to render itself at runtime (as opposed to edit time) is not something that is in our current product plans.
