It would be good to see a Survey123 Element in Dashboards Beta - much like what we see in Experience Builder (screen capture below). Adding a survey to a Dashboard with the Embedded content element is a pretty common workflow.
This would also (hopefully) lead to better control of the survey appearance via settings in the Dashboard; for example being able to turn questions on and off, reorder questions, and making questions read-only (as is often the case for close-out surveys where some questions are not required and some questions should be for information only).
Currently my workflow is to create a survey specifically for Dashboards so I have better control over how it looks as Embedded content vs in the mobile app for field data collection.
Jamie.
