Ability to Edit Data in Operations Dashboard
14463
34
08-26-2014 12:26 PM
JordanRogers
New Contributor III
     I was just wondering if there has been any consideration given to adding an option to allow the ability to edit data within Operations Dashboard?
     I am looking at setting up an Operations Dashboard for a Supervisor to monitor field edits from Collector.  Ideally, I would like to give the Supervisor the ability to edit some of the attributes in Operations Dashboard rather than using it to monitor field operations and opening a separate web map to edit.
     For example: if something is flagged as 'Needs Attention' by staff in the field, this would pop up in an Opeartions Dashboard query.  The Supervisor would then have the ability to assign a 'Work Order ID' and later change the attribute to 'Resolved'.
34 Comments
StuartMoore
this would be very useful, we would like to use Ops Dashboard as a running order for an update call with our management team and having the ability to add updates to the jobs as they go along would be really helpful
by Anonymous User
I know that the idea of a dashboard is mostly about the data insights... but in some cases, the interactive actions in Ops Dashboard would actually make it a very powerful platform for editing workflows!
Marco Wagemakers
RyanSchafer1
Agree with Alix here. In my case, hypothetical 'what-ifs' for our admin team could be investigated in real time from the dashboard in order to instantly identify macro level statistical movements.
KassandraRodriguez
The edit option would be fantastic as most of my colleagues don't know how to use GIS software so the easy looking  interface would be more appealing for them to use.
DelaereMickael
Hie Jordan,
Waiting for this ability too. Have created a list in my dash with a url targeting a webappbuilder app with editing ability i use url parameter to zoom to the "to update" feature .
Hope it will help you.
Mary_GermanWhitley
Given all the updates to Ops Dashboard, is this still not possible? I don't see anything in the menus, but want to double check.
deleted-user-qpvAI3Fo0MKR
Bump. I'm surprised this has taken so long to implement?
JamieLambert
We also use Ops Dashboard for issue tracking. When an issue is actioned, we need to edit some attributes to mark it as resolved - at which point it will no longer meet the filter requirements and will be removed from the Dashboard. Currently this is a two-step process because we can't edit in the Dashboard. Very frustrating for our (non GIS) users who want this process to be as simple as possible. They have a very low tolerance for the current workaround. Adding the ability to edit attributes in Operations Dashboard would be a huge improvement.
 Is there any activity within Esri relating to editing in Operations Dashboard?
MichaelKelly3
Technically you can do this as it stands by embedding a web app such as:
  • Web AppBuilder with an Edit widget along with a URL parameter - this will zoom to the specific feature after which the user can edit via the popup
  • Survey123 via editable web forms - this will open the associated pre-populated web form which the user can update as appropriate
JaromHlebasko
Thanks Michael! How exactly does someone go about doing this for the 1st bulleted item you have above? That is very intriguing to me.
