Known Limitations
2019
7
03-20-2020 08:13 AM
Known Limitations
With the release of the ArcGIS Dashboards beta, the team has put together a list of known limitations that users may come across. Most dashboards will open without issue in the beta. The following table contains the current limitations. Dashboards that include functionality labeled as Not yet supported may not open or the elements that rely on the functionality may not render properly.
Category
Functionality
Status
Layer Types
Tables
Not yet supported.
OGC (WFS)
Not yet supported.
Browsers
IE11
Not Supported: Support for IE11 is deprecated throughout the ArcGIS Online platform.
Edge HTML
Versions 17 and 18 only.
Actions
Follow Feature
Not yet supported.
Maps
Multiple Projections
Maps with layers in different projections may not be visible in your dashboard.
Stacked Maps
When maps are stacked, elements that reference the hidden map will not display anything until that map is exposed.
Pop-Ups
Visible Features
Non-visible features still appear in the pop-up.
Cluster Pop-ups
The pop-up for a cluster doesn’t provide the option to view details for each feature in the cluster.
URL Parameter
Locale
Numbers and dates will reflect the locale, but strings will not be translated and will appear in English.
Element Configuration
Sort By
Sorting in serial charts and pie charts that use CSV layers or feature collections as their data source will not sort when based off a field and will result in a “No Data” when based on a statistic.
Map and layer functionality that is not listed as supported in the Map Viewer Beta compatibility guide are also unsupported in the ArcGIS Dashboards Beta.
Last modified: 8/4/2020
Comments
Very useful to know and hope to solve the hosted table support soon, my dashboard was hit very hard with the beta
Before:
After:
I feel your pain...after trying to get this table to work, I stumbled upon this document and yelled at the sky! So many good advancements, in the beta, just really need "table" support!
Is the above a static list? Or as users come across issues are they been added? Media in Details elements doesn't work. This is a known issue and not on the list (Has the enable media in the details block changed in the Dashboards Beta?). Thanks.
Just got the error  "exceeded transfer limit error" with ArcGIS Dashboards Beta. This is with a serial chart.
Would like to know how I can solve this.
Anthony Twesigye
We recently fixed a few issues with that error appearing in serial charts. You shouldn't see this error once the beta is released again (Date TBD)
Any luck to adding functionality for tables in Dashboards Beta?  Very glad to see the Arcade pop-up support, but no tables is a deal breaker for now. Thanks!
John Solly Great to know this is being fixed. Lets hope we have the Beta version released soon.
Version history
Revision #:
1 of 1
Last update:
‎03-20-2020 08:13 AM
Updated by:
Contributors
