Only retrieve updates from one field
1849
06-06-2023 02:44 PM
MK13
I have a power automate flow that sends emails when updates are made to a web layer. I am only interested in updates made on a certain field, 'field1'. However, when updates are made to another field, 'field2' or any other field, emails are sent out. How can I set it up to only listen for updates from field1 or at least to retrieve the name of the field on which the updates were made so that I can use a conditional expression to check for updates on my field of interest, field1? @SeanKMcGinnis  @CoffeeforClosers
Tags (1)
SeanKMcGinnis
Hello @MK13 & @CoffeeforClosers,
Unfortunately, webhooks from ArcGIS Online and ArcGIS Enterprise do not identify which field has been updated, only that the feature layer itself has been updated.
You might want to add it as an idea in the ArcGIS Online or Enterprise communities to provide more detail in the webhooks.
-sean
Sean McGinnis - Principal Product Manager, ArcGIS for Microsoft
CoffeeforClosers
Unfortunately I offer limited insight as I don't have firsthand experience with the ArcGIS connector. If you would provide a screenshot of what the dynamic content options are from the connector that would be helpful.
MK13
 I have attached the dynamic content options. Let me know if you need anything else.
SeanKMcGinnis
-sean
MK13
Got it. Thanks!
AndrewWillingale
Hi @SeanKMcGinnis Has the functionality been added to AGOL and AGE webhooks yet to identify which field has been edited? If not, is it on the ESRI technical roadmap?
Thanks, Andrew.
