Help Configuring a Flow in Power Automate with Survey123 and SharePoint
570
11-17-2024 03:51 PM
Jeferson
Hello, Network!
I would like your help configuring the following flow in Power Automate.
I need a file to be created and saved in a SharePoint folder whenever a survey is recorded in Survey123.
It is important to note that I do not have Survey123Web credits to use the "Create Report" connector.
Is there any other resource I can use?
In my research, I found solutions involving the "Create Report" connector, but I am limited in using this resource.
I apologize for the translation.
jdaniel
Hi Jefferson,
I've never attempted to perform an action like this but, do you have access to the Sharepoint Actions in PA? Within this set of actions there is one called "Create File". That's where I would start. Beyond that, I would try triggering a desktop flow that fires off a Python script.
