Fetch updates, changes, or deletions failing to fetch photos from AGOL feature service
458
7
09-17-2025 09:53 AM
Caitlin_Todd_LCOR
Hello,
I'm trying to use Power Automate to set up automatic email notifications when a new feature is added to a hosted feature layer on ArcGIS Online.
I'm using the trigger "When a feature is created" and associated action "Fetch updates, changes, or deletions" to attempt to pull in any attributes and/or photos from the newly created feature and organize them into an MS Outlook "Send an email(V2)". I have the attachments being pushed into an array variable then added to the email as an attachment.
I can see the photo attached to the new feature in ArcGIS Online. But the output for Fetch updates, changes, or deletions is returning a null array for the attachments which is causing the action for Append to Array Variable to be skipped entirely. I copied and pasted the output  of the Fetch updates, changes, or deletions below.
    "body": {
        "items": [
                "attributes": {
                    "OBJECTID"2304,
                    "EventRdStatus""Tree - Impassable Road",
                    "HazardType""Tree",
                    "UtilityHazardType"null,
                    "RoadName""test",
                    "BMP"null,
                    "EMP"null,
                    "ClosestAddInts""test",
                    "RoadType"null,
                    "OpenLanes"null,
                    "ETA""test",
                    "ETC""test",
                    "GlobalID""ee50f36a-7b55-4410-a1fa-fbe889514607",
                    "TreeCount"null,
                    "TreeSize""test",
                    "TreeType"null,
                    "MaintZone"null,
                    "Supervisor"null,
                    "LocationNotes""test",
                    "OperationNotes""test",
                    "WERCSID"null,
                    "Response"null,
                    "CreationDate"1758125125262,
                    "Creator""name",
                    "EditDate"1758125125262,
                    "Editor""name",
                    "DateLastSent"null,
                    "Resend"null
                "geometry": {
                    "x"4187066.005184437,
                    "y"898857.0352970393
                "changeType""FeaturesCreated"
        "deleteIds": [],
        "attachments": []
I tested the flow with the Google Chrome Devtools to catch any more information and could only find a brief message when the flow was trying to append the photo into the designated array variable.
"error": {
"code": "AzureResourceManagerRequestFailed",
"message": "Request to Azure Resource Manager failed with error: '{\"error\":{\"code\":\"ActionRepetitionNotFound\",\"message\":\"The specified repetition '000000-000000-000000-000000' of workflow action 'Append_updated_attachments_to_array' is not found.\"}}'."
Has anyone else come across this kind of issue in Power Automate's ArcGIS Online actions? Specifically the Fetch Updates, Changes, or Deletions? Is there any other tool to use to troubleshoot the issue?
Caitlin T
Lane County GIS
AkshayHarshe
@Caitlin_Todd_LCOR , If the attachment is always created only when a feature is created then I would recommend you use something like this:
Else, Maybe another trigger like `When attachment is created` is more appropriate.
That said, I will look into enhancing this option to Fetch updates, changes, and deletions action.
Akshay Harshe
CalvinHarmin
To piggy-back on this, here is an example of an output of ArcGIS Connector for Query Attachment:
    "statusCode"200,
    "headers": {
        "ETag""W/\"143-SEyQLGQQvSDupHamIqbh1v32DBI\"",
        "Vary""Origin,Accept-Encoding,Authorization,X-Esri-Authorization",
        "arcgis_connector_version""ArcGIS 2025.2.0 2025.06.10 1749573664471 361de8",
        "X-Powered-By""Express",
        "x-ms-environment-id""<redacted>",
        "x-ms-tenant-id""<redacted>",
        "x-ms-dlp-re""-|-",
        "x-ms-dlp-gu""-|-",
        "x-ms-dlp-ef""-|-/-|-|-",
        "Timing-Allow-Origin""*",
        "x-ms-apihub-cached-response""false",
        "x-ms-apihub-obo""false",
        "Date""Wed, 20 Aug 2025 22:47:34 GMT",
        "Content-Length""323",
        "Content-Type""application/json; charset=utf-8"
    "body": [
            "id"133,
            "globalId""<redacted>",
            "name""IMG_2351.JPG",
            "contentType""image/jpeg",
            "size"4568873,
            "keywords""attach_images",
            "url""https://services3.arcgis.com/<redacted>/FeatureServer/0/567/attachments/133"
The body value is an array of attachment attributes (not the attachment itself). If no attachments are found for the specified objectid, the array is empty: []
As @AkshayHarshe pointed out, you would then use ArcGIS Connector Get attachment from URL to get the actual raw attachment file data for each attachment via the "url" value from each attachment you're iterating over from the Query attachment body.
Caitlin_Todd_LCOR
Thanks all for your time and advice on this. I'm trying to implement the suggestions you gave but still having the same issue where the Fetch Updates, Changes, or Deletions isn't recognizing that there are attachments to be found. I'm still troubleshooting when I have time, but for now I'm leaving the photo attachments out of the flow entirely just so I can get the flow running again for staff.
AkshayHarshe
Is this running on Enterprise or Online? Try using Query attachment. and use the dynamic content from the fetch action. I will check if there are anyissues.
Akshay Harshe
Caitlin_Todd_LCOR
This is running on Online. I tried Query but the Fetch action didn't recognize any attachments to be queried. When I try to test the flow it skips right over Query Attachment as it couldn't find anything to query.
This is the raw output from the Fetch action. Even though I tested with a newly created point feature it didn't fetch anything.
AkshayHarshe
So What is your trigger exactly? `When a guardrail note is created`. Is it feature created or Attachment created or something else?
And how are you triggering it? e.g creating a new record ?
Akshay Harshe
Caitlin_Todd_LCOR
The trigger is when a new feature is created in the hosted feature layer. Staff will typically attach a photo at that time as well.
