AGO Connections Failing.
340
9
2 weeks ago
TL2
Existing and new connections error out:
Tags (3)
AkshayHarshe
the ArcGIS for Power Automate containers are working as expected today. You may need to reauthenticate your connections. Apologies for the disruption and inconvenience. Please let us know if you have any persisting issues.
Akshay Harshe
tschrage
I'm assuming that there is an issue on their end today..... maybe due to updates?  I'm having flows (associated with the ArcGIS connector) fail left and right with a random json formatting error.
TylerGraham2
Same here. I've been having issues with it all day. My ArcGIS connection keeps getting dropped and I've been unable to save any Automate workflows with the ArcGIS connection.
ISP_graynic
We are also seeing random connection issues with the ArcGIS connector after not having any issues for months. Has anyone let ESRI tech support know about this?
We are also having issues with the "Create Report" action all of a sudden throwing a "The response is not in a JSON format." error and not running.
NataliyaLys
Same issue here. Starting this morning 6/9 around 9am my ArcGIS connections started dropping in Power Automate, I have been trouble shooting this all morning and no luck.
@AnthonyLatini @SeanKMcGinnis  anything changed on ESRI side?
CatHeindel
Same issue here as well
AkshayHarshe
Hi everyone, we are aware of this issue and currently looking into it.
Akshay Harshe
ISP_graynic
It looks like everything is working normally again this morning. Hopefully the connectors were fixed and we're good to go now. Thanks!
NataliyaLys
Everything seems to be working again as of this morning. 🤞 Thank you!
AkshayHarshe
Akshay Harshe
