Changing Header color in Attachment Viewer app
1249
03-02-2021 11:41 PM
PeterSmith3
New Contributor III
Hi, I've created an Attachment Viewer configurable app in ArcGIS Online and everything is working as expected. The only problem I have is that, when it comes to changing either the Header text color or the Header bar color, I am unable to select a different color. My only options are the defaults -  white for the text and blue for the bar.
I entered an alternate color into the Custom CSS box, and it changed on screen. However, when I published the app and launched it, the color shown was the default color.
Has anyone got a solution please? I would have expected that I would have the option to select from a palette of colors, as is the case with Web App Builder, but the palette is not visible.
Thanks.
Tags (3)
BrantCarman
I'm having this same issue.  Have you figured out how to change the colors?
PeterSmith3
New Contributor III
No, nothing as yet.
BrantCarman
I was actually able to open the survey from the Survey123 website interface and could change the colors from the "design" tab there.  I actually just ended up disabling header and footer for a cleaner look, but I'm pretty sure the options to change color would work as well.
