Unable to connect to Portal with Samsung Galaxy S5
1751
6
08-14-2018 12:29 AM
MagalyClément-Zaber
Hi !
I want to connect to my Portal in Collector.
It works fine on my personnel phone Wiko (Android).
With the same link, it doesn't work on my professionnal phone : Samsung (Android)
See the screenshots below :
Samsung, after registering the URL (https://mycompany.fr/portal😞
After registering the URL with the Samsung
Wiko, after registering the same URL:
After registering the URL with the Wiko
The two screens are differents ...
Samsung after "Poursuivre" :
Samsung error
Wiko connection is fine, I see my webmap...
Samsung collector :version 18.0.1, build 1031 same as Wiko
Connection works fine with AGOL account.
Any ideas ?
Thanks for help.
Portal 10.5.1
MagalyClément-Zaber
I updated Android from version 5 to 6 and it works!
by Anonymous User
Not applicable
Magaly, are you using named users created in the Portal or users imported from LDAP or Active Directory?
If using enterprise users (ldap/active directory), could you try entering the username as DOMAIN\username ?
MagalyClément-Zaber
Dan,
I've tested both.
No effect with DOMAIN\username
Lake_Worth_BeachAdmin
Android Parses out everything before the first "\"
try this:
domain\domain\username
MagalyClément-Zaber
It didn't work
Why does it work correctly on my Wiko and not on the Samsung with the same settings?
I think the problem is not when I enter my login/password but on the first screen, when I put the URL.
I put exactly the same thing on both phones but the screens after are differents.
Is there an Android application like Firebug to see the traffic generated at that time?
Thanks
by Anonymous User
Not applicable
Magaly,
You can use an application called Fiddler to look at the network traffic. You will need to have your phone on the same network as the computer you have fiddler installed on.
https://community.esri.com/groups/technical-support/blog/2014/12/10/smart-debugging-for-android-and-...
MagalyClément-Zaber
