turned on editor tracking and get the message cannot create replica
5317
07-08-2015 08:19 AM
ChristieRajtarova
New Contributor II
Using Collector 10.3.1on Android 5.0
New to this, we only got our first field map working this week, but not properly since we want to be able to take it offline and keep the editor tracking available
I have a couple basemaps on my device from a tile package I created.
I made my service editable and offline: versioning is disabled, archiving is enabled, sync is enabled
It downloads no problem at this point.... then I go back to the feature class and enable editor tracking and use specified fields.
I am able to edit points as long as I am connected to a network.
But the editor and creator fields are populated with "Esri_anonymous" which doesn't help us when it comes to editing.
Anyways....
The download button still appears in Collector
Upon clicking it, about half way, I receive an error message when downloading:
"The map 'TestStructures' failed to download with the message: Failed to create replica. Editor tracking fields must be visible"
1. my editor tracking fields are visible
2. why is it trying to create a replica? I have editing sync turned on so there is only one default version
Do you know any work arounds?
What properties do I have to enable for this to work?
MarcialCarbajosa
New Contributor II
In the Mxd and in the service this field mast be visible. i ussually have all the layers visible in mxd and in the feature service and i show or hide the fields in the web map.
MiaogengZhang
Regarding to "Esri_anonymous" , do you use ArcGIS Portal with ArcGIS Server? If so, is the server federated?
MarcialCarbajosa
New Contributor II
I have Portal for Arcgis 10.3.1 and ArcGIS Server 10.3.1 but the server is
not federated.
Marcial Carbajosa Alcántara
E.I.E.L
Planes Provinciales
Calle Burgos nº 1 • 34001 Palencia • Tel: 979715100 Ext: 2118 • Fax:
979715135 • Correo: mcarbajosa@diputaciondepalencia.es
Este correo electrónico y la información contenida cumple con la normativa
de la LOPD. La Diputación le garantiza la posibilidad de ejercitar
los derechos ARCO dirigiendo un escrito a la dirección indicada
anteriormente. Más información: www.diputaciondepalencia.es
<http://www.dip-palencia.es/diputacion/contenido?pag=/sites/diputacion/info_general/politica_datos>
2015-07-30 20:21 GMT+02:00 Miaogeng Zhang <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread> turned on
reply from Miaogeng Zhang
<https://community.esri.com/people/miaogeng_zhang-esristaff?et=watches.email.thread>
in Collector for ArcGIS - View the full discussion
<https://community.esri.com/message/539984?et=watches.email.thread#539984>
